Deletes a specified VRRP instance.
| vlan_name |
Specifies the name of a VRRP VLAN. |
| vridval |
Specifies the VRID for the VRRP instance. To display the configured VRRP router instances, enter the show vrrp command. |
N/A.
None.
The following command deletes the VRRP instance on the VLAN vrrp-1 identified by VRID 2:
delete vrrp vlan vrrp-1 vrid 2
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the VRRP feature, see the Switch Engine v33.1.1 Licensing Guide document.
